e maxx transmission
Serum
06.24.2007, 09:50 AM
If you use the drivedog, and remove the 1st gear (output, input and idler, so three gears can be removed) you also need a spacer to hold the output shaft in place. I used a nylon tube i had, i also removed the unused gear on the inputshaft.
Serum
Visit Serum's homepage!
Find all posts by Serum
Hybrid Mode
Switch to Threaded Mode
