glassdoctor
TEAM FUSION
glassdoctor's Avatar
06.25.2007, 09:54 PM
Some have used emaxx motor plates like that... that was my first one too. IMO it will be ok... there will be more flex that with a thicker one... but guys do run big motors on emaxxes all the time. But most of us here like to build things pretty tough... overkill is good type of thing. I would recomend you make a bracket/brace for the rear of the motor... even if it's just a simple piece of L angle bolted to the chassis snug up to the back of the motor.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
