06.24.2007, 08:56 PM
So it appears that both holes in the bottom of the mount were drilled about 1-2mm off to one side because the mount itself is square with the truck but the front mount of the stock diff is over a little bit from the alloy mount, basically the back is just shifted over from the front causing it to sit cock-eyed. So if the holes were drilled slightly off, how is Mike about swapping stuff out? I would rather not cut the chassis holes to slide it over.
