silentbob343
06.26.2007, 11:28 PM
Originally Posted by BrianG
Was the LVC set then? If so, it shouldn't have allowed the pack to drain that far if you were running it...
It does and that's what I am upset about. I had it set for li-poly normal. I must have run the battery down further than I thought, but I thought the LVC would kick in. Normally I time my runs and never use more than 805 capacity, but I was doing some shakedown runs and hadn't bothered.
It also has a manual LVC option which allows the user to choose from 2.2v-3.0v. I guess I will have to select 3.0v in this menu as well.
The battery is up to 12.3v and 83% capacity charging at 250mAh. I'll have to wait and see how much capacity it'll retain.
