kufman
06.27.2007, 01:25 PM
Statement #6
Losses are the current squared times the resistance. So... reducing the current draw by a factor of two lets say, reduces resistive losses by a factor of 4! So what you have said in #6 is true, the higher voltage system will run more efficiently.
Statement #5
Torque is proportional to the amp-turns of the motor. so what you have said in #5 isn't always true. a 10 turn motor running 5A will have similiar torque to a 5 turn motor running 10A.
#4 sounds correct.
#3 I think is correct.
#2 Is correct.
#1 I believe to be correct.
