It could also be poor solder joints as well? Have you checked all solder points for quality bond? Lengthy wires might be the culprit too, who knows?
I know I should have got the 8000mah. in the first place, but I am still not sure that it is the problem. When I take of the lisaver, there is no problems at all. It just flies away, with no "cogging".
When I am finished driving the lipos are hardly warm, but the motor is for sure.
Could this be a motor issue. Would it help me to replace the rotor with the HV 6,5 rotor (the cheap solution), or should I upgrade to a senserless system?
