08.27.2007, 07:20 PM
Its all your own fault for having a flashy expensive good quality radio, you should have bought an older out dated model like me ;) I had a problem programming my HvMaxx the first time- it would not work unless I set the throttle epa down a few notches ( adjustable pot on the tx ), after that it worked fine, no problems at all. Since you have reset everyhting, I would recommend setting the throttle down to where you say it idles maybe, then connnect it to the esc & try reprogramming it again. Hopefully the esc will recognise the radio is at 'neutral', and it wont want to go ka-ka on you every time you turn it on after reprogramming it. I think the problem you may be having is to do with the fact you can adjust the tx between 120%? and 0% on the throttle, where as the esc wants to see 100% & 0%. By pulling full throttle & gradually turning the throttle epa down whilst programming the esc it should hopefully recognise the point where 100% is. If I try to turn the throttle epa back up past 100% the esc wont function. Weird, but hopefully that info should help you.... or just confuse you.....
