VintageMA
VintageMA's Avatar
08.29.2007, 08:33 AM
Originally Posted by dway View Post
I think regular lipos would be a better choice. You are only going to have enough room to run a 4s1p pack at 13.2v 2300mah or a 2S2P pack at 6.6v 4600mah. I don't think either one is a very good option.
dway - Comments like this without any technical support on the statement don't carry much weight around here. Do you have any technical reasoning behind your comments?
I also have 2 of the MaxAmps 3S 5000mAh packs myself, but I actually opted to go with the A123 batteries for several reasons:
-Weight - the weight of a 4S A123 pack will balance out nicely against a 8L and ESC mounted on the other side of the car.
-Amp draw - this buggy weighs like 5lbs wet - the highest peak current draw on my BL LST2 with a LMT 1950/7 and 6S in a 14-15lb truck is 85Amps. So I have no concern with there being a current limiting factor.
-Motor - at 3019kv the 4S A123 puts the 8L right in its sweet spot.
-Safety - I've had 4 2S 3700mAh lipo packs (the Firefox ones from FDM) balloon and swell on me just storing them at ~50-60% charge. This has me very concerned as I live in an apartment and don't have a garage. Even though I store the cells in a metal lock-box - I get worried about fire now. If the A123 cells prove them to me on this installation I may consider getting more of them.
Re: the volt drop on the cells - check out the pdf in my first posting. @25*C w a 30A load the cells show a running voltage of ~2.8v. Just like jhautz - this is why I will run 4S A123 instead of 3S Lipo.
JHAUTZ - I'll post some pics on this thread as I am building. A few questions for you if you've thought out some build issues.
1 - What are you going to be using for the battery mount? This is the one place my customization and craftmanship skills always struggle.
2 - Do you think I should get a UBEC as well for the 4S A123? I was going to try the BEC in the MM - but I know I've read a lot that the MM BEC gets hot even on 3S LiPo.
“Everyone has a right to be stupid; some people just abuse the privilege.”
Mailman
08.29.2007, 05:34 PM
I think BrianG answered this for me -(I had my user name changed from dway)
There is nothing "technical" about it I was just stating my personal opinion. If you don't mind running a 6.6v battery and getting poor performance but longer run times , or a 2300mah battery and getting better performance but lower run times then go ahead. I can understand wanting to do it for the safety aspect of it, but either your performance or your run time will suffer. The only reason I suggested a lipo was that you get the voltage needed and run time too.
VintageMA
VintageMA's Avatar
08.29.2007, 06:24 PM
Trust me - I am a big LiPo fan - I've probably spent $2K on LiPos alone in the past 2 years. But after having $500 worth of (well cared for and balanced regularly) balloon on me - it's time to try something a little different and see how it works. I went with the 4S config on the A123s because that's the closest to 3S Lipo - so I obviously want the performance.
We'll see - maybe I'll end up using the 3S 5KmAh MaxAmps pack in the long run. I plan to setup with a battery mount that will support both.
And if I set the MM for a 9Volt cutoff I will be able to interchange either the A123s or the LiPo w/o making any changes to the cutoff on the ESC. For 3S lipo it will be right on the mark at 3v/cell and for the A123 it will be just a touch higher than the recommended 2V @ 2.25v/cell.
Give it a month to have everything shipped and we'll see.
cemetery gates - what gearing are you using with the 10L and what brand is the motor? I've noticed the Feiago motors will tend to pull higher power spikes than the LMT/Neu's with the stronger magnets.
cemetery gates
08.29.2007, 06:28 PM
It is a feigao 10L geared 20/46 (tops out at 39, radared). In my revo with a neu 1515 1y on 4s and I get many 120+ amp spikes. In your case you are running 6s with a lower kv motor so, you will pull less amps...
Bye
VintageMA
VintageMA's Avatar
08.30.2007, 02:19 PM
To move back on track with my original post - the parts are coming in.
Got the Hacker B50 8L today - feels like a nice solid motor. Not a Feiago but not quite a LMT/Neu either.
Got the motor mount and pinions in from Mike - very quick shipping as always!
Got the A123 batteries and charger - the A123s seems like some solid cells. Small issue with the charger though - it let it's smoke out ;) Hooked it up to me DC power supply and the lights were wigging out on the charger. Played around with it for a bit and when I went to hook it up the second time and tried tohook up a battery for charging a puff of smoke came out of the front of the charger. A123Racing has alrady agreed to repair it at no charge if I send it in, but considering it is dead out of the box and am trying to see if Horizon Hobby will do an RMA first before I send it in to A123.
Guess I'll be starting the build and testing this out with the 3S 5k mAh lipos anyway.
Now all I need is the buggy - FedEx Ground coming from CA seems to be taking a while - was hoping to have it for the long weekend.
VintageMA
VintageMA's Avatar
08.30.2007, 03:29 PM
Good support from Horizon Hobby - they are arranging a RMA for the charger.
cemetery gates
08.29.2007, 06:10 PM
I have a crt.5 w/ext chassis that runs a 10L(2458 kv) off of 3s(weighs about 5lbs). I have seen 90+ amp spikes out of this so, you might be suprised at how many amps an 8L can pull, just to let you know...
Bye
jhautz
jhautz's Avatar
08.30.2007, 05:30 PM
I typically just use some velocro on the chassis and the pack, then strap it down with a gorilla maxx strap. I havent had any issues with it yet. If it were lipo I would make some sort of box out of Carbon Fiber angle stock or aluminum or plastic to protect the cells more.
Yes, use a UBEC for sure. A cheapo will due just fine for this small truck. Just get a $15 one from one of the flyer websites.
Sorry for the delayed response. I didnt catch that you asked a question at the bottom of the post.
jhautz - What servo are you going to use. I picked up the HiTec HS-5245MG, but I've seen some threads on here about people overheating them with too large tires.
I've always had very good luck with HiTec digital servos, and I am planning on making the jump to 75MHz FM to DSM2 when the Spectrum DX3R radio comes out this fall - so I wanted something solid that I could run at a higher frame rate.
I'm using the same one. Just ordered it a few days ago. Should be here soon. On the plus side the CRT.5 showed up yesterday. (grin)
to make it...
or break it...
Silent...But Deadly
VintageMA
VintageMA's Avatar
08.30.2007, 10:37 PM
The buggy should hopefully arrive tomorrow for the weekend.
I guess I am still missing the UBEC - can you send a link to one?
Any idea what you are going to use for the diff fluid? I've been reading 3K f/3K c/ 1K r is a popular starting point - but I am wondering if it would be better to go go with the standard 3/7/1 used for buggies - I'm never sure where to start with that as I mostly just bash and don't race.
jhautz
jhautz's Avatar
08.30.2007, 10:44 PM
Just look around. there are alot of places that sell em. Mike has a higher end one in his store.
to make it...
or break it...
Silent...But Deadly
VintageMA
VintageMA's Avatar
08.31.2007, 02:40 PM
Just got the CRt.5 in today - WOOHOO!!
Thought this was cool. I ordered it from A Main Hobbies and it came with a 2nd set of wheels :)
Let the fun begin.
