Go Back   RC-Monster Forums > Support Forums > Team Tekin
lutach
lutach's Avatar
08.31.2007, 12:29 PM
The main reason people like to see a ESC handle 6S, 12S and even 15S lipos is to have the option of either running higher AMP draws or less AMP draws. I have my share of ESC and I ran my BBP truck with 10S lipos and it ran great. The wires were warm, the motor was around 160 and the ESC was warm and so was the lipos. Now with the batteries in parallel, the wires were hotter then with the packs in series. Also, the reason to have a ESC handle higher cell counts is to keep the ESC safe from voltage spikes. I would feel better if the ESC could handle 12S, but I only ran 6S. Like my Schulze 40.160 on 5, 10 and 12S set up was just warm to the touch. I heard people running that thing up 60 volts and it does arm at 60 volts. Higher voltage less AMPs and from what I have seen less heat then with the lower voltage set ups.
