snellemin
2 KiloWatt RACER
snellemin's Avatar
09.03.2007, 02:43 PM
What is you timing set on and on what surface are you riding on? What tires are you using? Could also be that you have some binding in your driveline somewhere. 14/90 is a good gearing with that motor on 3s.
I found out that the stock transmission case use to flex, causing me some broking spurs. Upgraded to the FLM tranny case and never had a issue after that.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
