dadgummit
09.04.2007, 03:11 PM
I like the idea of using the Jato spur gear. I just looked on tower hobbies and it says "54T 0.8 Pitch Spur Gear"
Is 0.8 pitch the same as mod 1?
Will it fit under the rustler's gear cover?
I thought the 15 series neu motors all came with 5mm shafts. I was trying to get away from having a custom pinion gear made.
Thanks for the quick replies!!!
09.04.2007, 03:59 PM
The jato spurs will not fit under the stock gear cover, but it does not matter as 32p gears are not affected with dirt and grit like the 48p ones are. I run my pede with jato spurs and emaxx piions and have never had a problem stripping gears. It is also quiter than 48 pitch and smoother too. I wonder why traxxas still uses the 48 pitch?
Cartwheels
09.04.2007, 04:10 PM
Another possibility a Mega Motor ACN 22/30/?. You can get those with 1/8 inch shaft. They are 6 pole motors and work great with the MM. I think Mike can get these motors too.
Then you can stay with 48 pitch or go 32 pitch.
