09.04.2007, 09:25 PM
From what I've read, the HV systems are sensitive to gearing, so don't discount that just yet. You have nothing to lose by trying it...
ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
09.04.2007, 10:17 PM
sweet MOTHER you have that HV system geared way higher than it should be!
i had a 4400 system with a 6.5 rotor for over a year in my maxx, geared with a 70t spur and 13 tooth pinion, with dual 7 cell packs. temps were in the 120's for the motor and esc, and the batts were at around 100 degrees. if i went up to a 15t pinion with the 70t spur, everything shot up about 15-20 degrees.
you have an enormous gear ratio difference between your maxx and your revo. your maxx is set up for a hv system. your revo is geared to thermal. in no time.
Eflite Blade 400 heli on 3s
JThiessen
JThiessen's Avatar
09.04.2007, 10:54 PM
Yes, it was geared way too high. But seeing as I havent ever run it, I havent thermaled it. Like I said before, when I first put it in, I had problems with the forward/reverse being backwards, and I didnt get the differential flipping done until a week ago.
I tried gearing it down, went to 15/66, and still nothing. I also tried lifting it off the ground, but still didnt get anything this time.
When I squeeze the trigger, sometimes there is a small lurch, but most of the time nothing (forward or reverse). If I keep the trigger squeezed, I can see the motor twitch a little, and hear it clicking. I watched the lights on the ESC once when i did this, and I got 6 flashes of the green and blue lights. I looked in the manual, and it doesn't say anything specific regarding that, except that it may have suffered a possible locked rotor, and refers me back to the ESC set up.
One other thing. When I first put the motor in, I may have run one of the mount screws in too far. I say may, because I dont remember for certain. I ended up stacking some washers under the head until I was able to trim them down.
