Originally Posted by What's_nitro?
Does it have the same chassis bolt pattern as the Rustler, at least on the lower deck? If so you could use the RCM-RC Carbon-fiber Rustler chassis. You can buy the lower deck by itself if the top deck bolt pattern is different. It looks that way from the pictures on the TRX site.
The SRT actually has a bulkhead in front of the transmission, I'm not sure if it will bolt up. With the exception of that, I figure its about the same, overall design is almost identical
