Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
smhertzog
Breaker of all that is Stock
smhertzog's Avatar
09.07.2007, 09:33 AM
I had the 160 and even with the reverse off it still had brake issues, and it also felt like the drag brake was on even when it was turned off. This was the 2.41 or 2.43 version I cant quite remember which one. The 3.5mm connectors got very hot (enough to almost melt the shrink tube) and would also pull out every once and a while. It was a pita to program too. I'm not sure about the newest version hopefully they fixed the above problems but its something you want to ask about before you buy one. I drive my trucks hard in race conditions for long periods of time. If you bash you might not even notice the above problems all but the pita programming that is.
mkrusedc I like the Quark but I had to mod it to keep it from heating up and blowing caps. The MM is excellent but it also has to be modified to be used with the Neu motors as you probably know.
Never fight an ugly man..... he has nothing to loose
