09.07.2007, 11:01 AM
A little jealous of you guys with the newer 16024s!!! Mine is about 1.5 yrs old and doesn't have the built in BEC.
“Everyone has a right to be stupid; some people just abuse the privilege.”
NeuMaxx
09.07.2007, 11:41 AM
Thanks for the help! I appreciate it.
Does Mike have the 1624s? I did not see them on the site.
That's All Folks!
09.07.2007, 03:12 PM
The new 16024's have no BEC either, only the 6s and lower controllers do. (16018, 22418)
09.07.2007, 05:03 PM
So still not as good as having a true UBEC in the car anyway.
Soldermaster Extraordinaire
09.07.2007, 06:04 PM
Yeah the 24's and 32's are Opto-coupled controllers. So you will need an external BEC.
NeuMaxx
09.07.2007, 06:18 PM
What does the difference in the amp rating on the MGMs mean? Sorry if this seems obvious.
09.07.2007, 06:20 PM
It is exactly how it looks. Though I will say it is the continuous rated current, not peak.
NeuMaxx
09.07.2007, 11:28 PM
Would it be correct that the higher the amps the cooler the esc will be?
09.07.2007, 11:32 PM
If you run 100A through a 100A controller and a 150A controller, the 150A controller should be cooler since it's not working to 100% capacity. Also, the higher current ESC usually has more FETs so the paralleled Rdson values are paralleled as well reducing resistance (and heat).
NeuMaxx
09.07.2007, 11:40 PM
Thanks. I did quite underatand that but I got the general concept.
