glassdoctor
TEAM FUSION
glassdoctor's Avatar
09.08.2007, 10:31 PM
I'd run it a while before doing any modding...
And I would keep the switches just for convenience. For example, if you are ever racing.... you can plug the battery in, put the body on while waiting for your race, and then just flip the switches to go. It's really not a big deal... as you can just use the battery connection as the primary "switch". Really, you can solder up both switch leads if you want.
ps: I have removed or replaced the swithes on my MM because I have had them fail during races... :( but assuming the switches work properly there is no reason not to have them.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
