jnev
jnev's Avatar
09.22.2007, 09:07 PM
What a beauty. That thing should be driving down the red carpet.
How is the Lehner 1940/7 and MM doing? It should run normal because it is a 2 pole motor.... Does the MM heat up a lot in such a big MT? I have only tried the MM in a 1/8 buggy which is quite a bit smaller than yours, and it heats up quite a bit, which is why I added a fan. Is yours similar in terms of heat?
