I've been testing a Mamba Maxx with 5700BL motor with 3S lipo the MM esc gets too hot and shut down after about 5 mins Temps get around 125F. Is the setup under sized for a Emaxx or would a cooling fan on the MM esc help from shutting down? Motor runs cooler about 85F but I have a cooling fan with heat sink on it. Also I use the Ubec from the MM would it better to have a seperate Ubec?
