AAngel
09.23.2007, 03:30 AM
For a buggy and track running, the 1512/1.5Y or 2.5d are hard to beat for 4S and are downright wicked on 5S.
rchippie
rchippie's Avatar
10.31.2007, 05:33 PM
Well i just did my first test run with my 1950-8t hi amp. i must say the motor is very very smooth with my 9920 esc. the temps after 8-10 min of running in front of my apt. the esc was 120, the motor 125, & the FP lipo was 96. So far im happy with it. im running a 15/46 gear & the speed looked good. I'll have to take it to the track to see if it needs more gear. I was not using the rc- monster heat sink. The 1950 feels smoother than my 9XL with the same esc on both motors.
REAL MEN RUN BRUSHLESS
lutach
lutach's Avatar
10.31.2007, 08:50 PM
Make sure you seal your 9920. I burnt my 3695 after running it in a baseball field. My friend at Flextronics said, "It is amazing what a few little rocks do to electronics." It was funny how he said it though. I think the same issue happened with my Quark which was running fine, but when I went to another baseball field it went up in smoke. I also saw a video in youtube of a Japanese guy who made a battery using what it looked to be stone that he ground using a coffee grinder (free energy). BTW This is not an issue with controllers that uses conformal coating.
rchippie
rchippie's Avatar
11.01.2007, 05:25 PM
Well i ran my 1950 again today. This time i used a novak HV heatsink & some compound. The temps were really good in my opinion. the motor temp was 125 & the heatsink was 118. so the difference was always 10 degrees or less. Usually the difference was closer to 5 or 8 degrees difference between the can & heatsink .Thats pretty good i think.
