Charlie
09.24.2007, 02:55 PM
Hey Guys,
You can always email us directly for assistance, Tech@teamnovak.com CS@teamnovak.com or Charlie@teamnovak.com
I always have a hard time "nailing" a particular problem to the wall with out testing the system first, but the basics have likely been covered, connections, wiring and bad plugs. I've seen and had Deans plugs that when inserted completely will cause the system to "misfire" or not start. The solution was simply not to plug them in all the way. I don't know if this is common, but I had 4 packs that all had the same issues. Replaced the deans and Voila problem gone. It's worth looking into at least.
