Duratrax raze motor mount
brushlessboy16
brushlessboy16's Avatar
Duratrax raze motor mount - 09.24.2007, 08:04 AM
Hey guys, i have been working ona duratrax raze conversion, will a rcm ofna mount work on the center diff??
Serum
Serum's Avatar
09.24.2007, 08:25 AM
Can you hand some dimensions of his original diff mount? Is there an off-set in the lower and the upper holes?
brushlessboy16
09.24.2007, 03:08 PM
no the holes are level.
brushlessboy16
09.24.2007, 03:12 PM
the full build up can be found here..
http://www.rcuniverse.com/forum/m_62..._1/key_/tm.htm
gimme a break im 15 and on a limited budget.
spaz163
Functionality with a dash of Form
spaz163's Avatar
09.24.2007, 05:48 PM
Not sure if any of the mounts will work or not but I emailed Mike and asked about him making me a custom mount for my buggy and he said for a one off mount it would be about $80. Just for your info.
What I ended up doing for my Ofna buggy was using 1/4" thick aluminum that I had bent at a 90 degree angle and I then mounted it to my center diff and my chassis. It appears to be able to handle anything I can throw at it!!
