rchippie
rchippie's Avatar
09.28.2007, 12:42 PM
Do you have any servos hooked up when you program it? I ask this because if there is an issue with a servo and it is pulling too much current for the UBEC to handle, the UBEC may be causing the receiver to malfunction. A receiver pack has more current capability. If that's not it, try a capacitor on the UBEC output to help eliminate any noise. I assume you disable the built-in BEC when using an external BEC or Rx pack?
yes i pulled the black bec jumper. Yes i have the steering servo hooked up. Maybe i popped the UBEC. I dont have any caps to put on it. If i have to run a reciver pack it's no big deal. Im going to buy a new controller any way.
REAL MEN RUN BRUSHLESS
