Thread Tools Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
Finnster
KillaHurtz
Finnster's Avatar
09.28.2007, 10:00 PM
I am using the hyperion 1210 with my 2 5s1p A123 connected in series. With 10s A123 the charger starts at 5,4A and finishes at 4.4A. A full charge takes around 32 minutes (without balancer). The more the cells are out of balance the longer it takes (even witout balancer).
But the hyperion 1210 also starts slowly when the cells are below 29-30V. Therefore i charge 1 minute in 9s mode @ 5A and then switch to 10s mode.
Although A123 cells do remain quite good in balance, they are not perfect and do start to drift in voltage. I too now will buy a lba10 or a Astro blinky for A123. Balancing during every charge cycle is not necessary. So one balancer should suffice.
As of april 2007 the LBA10 "net" balancer is compatible with A123 cells.
Hmm good info. Too bad to hear about the slow start tho, but 1 min of 9S isn't too bad. w/ my 5S2p A123 batt, 4S A123 is too low, and even 4S lipo just goes to cv mode quickly. Way too much fiddling needed when these cells are uber safe. I do have a blinky FWIW, tho I rarely use it. The cells go out on full charge, but then even off after a bit
