10.04.2007, 01:17 AM
Yep, rebadged version of a european vehicle IIRC. Diffs are a little harsh, but should be fine after a little break-in. Truck is slightly smaller than an emaxx, and uses a body that would fit a crt.5, looks funny from some angles, but not bad. Diff cases and arms look very sturdy, not much else save the TVPs and wheels, truck is very simple. Ctr gear is mod 1 and it doubles as the brake disk! Has a straight shaft to the diffs from the spur, no cups or dogbones to wear out. Spur has a large square cutout that mates with a square portion of the center shaft. Radio box makes a good mount for the esc, with the lid removed. Servo is directly below it, hooks to a double belcrank steering with beefy turnbuckles. Not HB/Ofna quality, but no worse that traxxas or duratrax and alot beefier than an emaxx IMO. Only real problem is that the tires do not have foams in them. No one on the terror forum seems to care, the truck only weighs around 9lbs with fuel.
