kulangflow
Never Fast Enough
kulangflow's Avatar
10.04.2007, 08:35 PM
Thank you immensly!
It totally makes sense now. It actually came with a jumper for those two pins, so that's in good shape now.
I learned that the cylinder thing is a 5V light that will indicate when the power is on. It's unnecessary though because the internal fans are always on when the ps is on.
Would you bother soldering the flag type connectors (leftmost in pic 3) to the connectors in pic 5, or will a pressure fit be sufficient? Will one ground lead be enough to get the full 30A, or would it be better to double up the ground wire.
This will be powering my new Hyperion 1210i when it arrives. I think it will work great. Thanks again for your help!
