10.04.2007, 08:45 PM
Originally Posted by ClodMaxx View Post
the novak fan i have is 5v but the only slot open on my rx is the second channel. i guess i could configure the spektrum to switch the fan on with a button...unless maybe it just automatically turns on when plugged in. (the battery slot is taken by a rx pack)
All receiver slots have power (middle connection) and ground (spot usually nearest the outside of the rx module). If the battery slot is filled, use the CH3 slot. The fan will come on right away. You could also use a servo Y adaptor cable, or make your own. Either way works.
Hmm, seems to me like an electronic-modding (PS modding, etc) specialty-adaptor-cable (Y charging/balancing adaptors, servo wire adaptors, etc) division of Mike's site would be popular...
