Duster_360
10.06.2007, 05:39 PM
http://www.robinsonracing.com/catalog/revo33.html ??
Not familar with the revo, but this may be what you're looking for.....
david lamontagn
10.06.2007, 06:17 PM
Pavement is killer for any plastique gear
I'am to build my e-revo and i was not sure if i 'll put the robinson gear kit, but now, it's order right now
david lamontagn
10.07.2007, 08:47 AM
Have you open the tranny to see if it's the gear who's broken or just the pin who hold it on the input shaft?
10.09.2007, 11:01 AM
Yes, check that. The gears seem to hold up fine, but those chintzy pins do break and that has the same symptoms as a stripped gear. With a little modification, the output shaft pin for a Jato works well. It's just a tiny bit bigger and is made of stronger metal.
