MetalMan
MetalMan's Avatar
10.06.2007, 11:18 PM
Good question about the mounting hole pattern on the 1112. On the Neu website it says the 1112 is 1.14" in diamater, which is 29mm. Standard 540 motors are 36mm in diameter, and have a 25.4mm mounting hole pattern (25.4mm between the screw holes). My guess is the 1112 has a 20mm screw hole pattern, but there's no way I would know... I'm sure you could contact Neu, they would know :).
