Assumeing the 2 boats weigh the same have the same power and the same sharpness of edges, a hydro has the highest speed then cat then monos.
A shallow V mono submerged drive mono turns the best followed by a cat, then a deepV mono then a hydro.
I prefer cats myself they are nearly as fast as hydros (I've placed in hydro races with one of my cats), turn as well as I want to turn, and handle water nearly as rough as a deep V,
You can make a good deep V turn as well as a cat with big turn fins but that will increase the speed difference between them.
The biggest advantage to a deep V is you can make them self righting, and I haven't found a way to get a cat back on its feet.
Here's my little cat 18" long, 400 size Mega 16/15/3 BL motor (watercooled), 30 amp Hyperion plane ESC (watercooled), 3s2p 10C Tanic 1550s totaling 3100mah, .098" flexshaft, plastic octura X431 cut down to 28mm, nothing gets much over blood temp.
Video
Xray XT8, 1518, MMM, 4s5Ah.
Lots of boats.
fastelectrics.net
