aqwut
Brushless Heavy Weight....
aqwut's Avatar
04.08.2008, 05:06 PM
that angle aluminum you're using looks very thin.... there might be quite a bit of flex there..?
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
Thunderbruiser
Thunderbruiser's Avatar
04.08.2008, 06:01 PM
not going to use that...really was a tester i have think aluminum that ill be using but i want to place the motor above the center diff towards the rear and then have a battery on both sides i'll snap some pics of this in a little...but yes that L aluminum has way too much flex i could pull it back and forth lol
Caster Racing Team 09'
Sik Wit It Racing Crew Fo life
garage:
E-CRT.5 brushed for now 13x2 orion(tekin g20)2s 5200mah lipo
  Send a message via Yahoo to Thunderbruiser Send a message via AIM to Thunderbruiser
04.08.2008, 06:04 PM
Motor over diff = easily do-able: Clicky
Thunderbruiser
04.08.2008, 06:48 PM
exactly i want to do that cause it'll be so cool
that's a clean install
garage:
04.08.2008, 07:18 PM
The only issue I fore-see is that the rear chassis braces bolt onto the chassis right behind the center diff, so you may need a rather funky motor mount that bridges over that area, and bolts to the chassis with some new holes that could be drilled, then bolt it to the existing center diff too for extra security. Should be able to work something suitable out though, and I hope you do, since I really like the look of the Mantis too for a conversion....
othello
HV basher
04.08.2008, 08:32 PM
A second way to place your batteries on both sides would be to turn your center diff by 180 degrees so that the spur now faces the front axle and place your motor on the opposite side of your steering servo. This might give you a better front/rear balance. But battery pack length will determine if you can do it this way (mine measure 135mm/5.31in lenghtwise).
Here are 2 pics how i started my Mantis conversion: pic1 and pic2
. I posted my conversion with videos of its maiden in this thread.
. A Video of the same setup running on snow with eagletree Data inserts can be found in this thread.
After having some issues with a loose endbell on my Neu 1512 motor i installed a Neu 1515/2Y motor which has even more torque.
. Video showing performance on asphalt
. video showing performance on gras
. Latest video driving on my favorite bashing space
After more then 220 runs with the brushless Mantis i can safely say it's a good brushless truggy platform but it has its weak spots like every car. I now run my truggy without rear wing because it can put too much stress (when cartwheeling or falling on its wing) on the weak shock tower mount. I already replaced it five times: pic1 (with german description), pic2 (broken piece)
Check your diffs and shim them properly. Brushless motors without a clutch put a lot of stress (instant torque) especially on your rear diff.
Looking forward to see your conversion pics. Your suggested brushless components will for sure be more adequate for a race track.
DrKnow65
DrKnow65's Avatar
04.08.2008, 09:26 PM
I'm thinking of doing the same thing with my hyper7, I'll give up a bit of the center of gravity to have an even balance and much cleaner setup...
Thunderbruiser
04.09.2008, 12:39 AM
othello i actully did that because while cutting the metal i cut too much off but had enough left width wise to mount and so the motor is towards the front!
pics:
updates tommorow
garage:
Thunderbruiser
04.09.2008, 05:28 AM
yea o this truck is plagued by that...but since i've tried to sell/trade so many times without success i said i may as well do a brushless 1/8th since i've been wanting one and i've had the 10xl for a very long time i am hoping to have everything installed tommorow except for my steering servo which i'll have to wait a little on..but i wanna show it to my team mates even though i know they'll talk trash haha(you're weird.....get a jammin.....sell that....) haha things i always here! but yea more complete pics up tommorow
garage:
othello
HV basher
04.09.2008, 06:40 AM
Looking good so far. Make sure your motor doesn't flex when pushing the rear end from left to right or top to bottom. Otherwise your pinion and spur will wear out quickly. What center diff bulks did you use? Still using the mantis center diff? You really have to secure the enbell of your Feigao (RCMonster heatsink for example). The endbell of my Neu 1512 loosened itself after some frontal crashes with the motor placed in the same position. The second drawback with this motor position is dirt/stones projected directly on the motor. You might want to think about some kind of mud guard to protect your motor (especially the bearing of your endbell).
Let them talk trash ... when they see it accelerating they might want to throw their nitro motors in the trash right away .
Thunderbruiser
04.09.2008, 02:29 PM
haha yea i race nitro with them but i don't always feel like dealing with that...yea i need an rc monster clamp for the motor...and thanks for the tips and input...getting ready to go out there right now and put the finishing touches
oh almost forgot that's a jammin buggy center diff....don't have the original mounts anymore...i'll see how it works it might not go so well if that's the case i'll find a way to mount the 52 spur again...using the same bulks....
garage:
Thunderbruiser
04.11.2008, 04:55 AM
more pics:
temporary layout for running arond the yard everything needs to be more secure for off-road...
garage:
Thunderbruiser
04.14.2008, 03:00 AM
this thing glitches going away from me but runs fine coming towards me..is that because of the fm(synthersized radio?)
garage:
DrKnow65
DrKnow65's Avatar
04.14.2008, 11:44 AM
Propably the way you have your wires ran, try getting the servo/esc wires away from the motor wires. Also move the antenna as far away from the esc/motor as possible. If that doesn't do the trick try putting a small capacitor (10v 330uf) on the power wires to a servo or if you have an unused 3rd channel port in your reciever and a spare servo connector you can build a "plug in" capacitor too.
I've never seen if fix a glitch but braiding the motor wires is supposed to cancel some of the RFI (radio frequency interferience).
t-maxxracer32
t-maxxracer32's Avatar
04.14.2008, 11:53 AM
if you were to get spektrum im sure everything would change.
