10.12.2007, 12:39 AM
I have the flm housing and am still killing the planetary gears. Had a look around and an emaxx diff may fit with some mods. Thinking that I will hollow out the stock vxl steel/plastic diff and use it to replace the ring gear on the emaxx diff cup. The bearing holes on the tranny cases will have to be enlarged to fit the maxx bearings, and I may have to have a ring machined to make up the difference b/t the pede diff and the emaxx diff cup, the diff cup is slightly smaller in diameter. I will try it as i have all the parts sitting around.
