sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
10.18.2007, 11:48 AM
A 10l on 4s is not that high draw of a system. I have my 10l on 4s in a LS10 with a mm running it and it works fine. My truck is reasonably light, what truck are you running this in? I am sure that the 9920 will work fine, especially on 5s. The 10l may be spinning a little fast on 5s, a 9xl would be a better chice, or maybe a 12l. Kv rating somewhere near 2000 is more suited to 5s as it keeps motor rpm near 35k.
It's a Hyper 7, so not too heavy. Yeah, it's obvious now that I picked it for 4S running now, isn't it? Hehe, oh well. I agree, you are spot on with using a 12L or 9XL. The "Mr. Overkill" in me says "do the 9XL" but that may be an awful lot of torque for a 1/8th buggy! I can also get to 4S real easy by buying another Apogee 2S 3800 pack. I've been running it with NiMH and I'm "ok" with the performance, but after throwing the eagletree on there, it's obvious I'm getting a LOT of voltage drop. I think 4S on that would feel pretty peppy from what I'm experiencing now.
Originally Posted by othello
Difficult to say. BK ESCs weak spot ist partial load handling. They do heat up quite easely. If you drive a lot at partial load then the bigger ESC should be better suited. Otherwise i do not see a prob using a BK9920 in a buggy with a 10L motor.
Well, this will be more of a basher/toy than a racer. It'll prolly be spending most of its time full on, coasting or full brake, heh. Although if I get on the track, i'll be feathering the throttle more, I'm sure.
BK ESC do not have a proper lipo cutoff. You will need an external LVC.
Ew. Forgot about that. I know about the LOA, anyone have any other favorites?
Good input!!!
Anyone else?
Sleeb
