BlackedOutREVO
10.22.2007, 05:31 PM
Correct me if Im wrong, but arent the diff cases the same externally, just different internally to accomodate the different bearings? I checked the part numbers on the exploded views, and the bulks used on both the new Emaxx & the T-maxx3.3 are same, so you will be fine to use any aluminum bulks you like....
Either way, I wont have the money right away to get them, till they start to break (I dont bash that hard....) Then upgrade
I want to see what traxxas will come out with also
