Aragon
10.23.2007, 09:20 AM
It will be interesting to see how mine works out. I will be running 10S so my current draw should stay below 40A. I wish I had purchased a 1907 instead of this 1912. I'm 90% certain 1912 will be way overkill, and a 1907 is 100g lighter (and cheaper of course).
My biggest concern so far is my gearing setup and the fact that these Neu 1900s cog quite heavily. The cogging might be a bad thing for coasting and I suspect might cause startup issues.
Aragon
10.27.2007, 10:52 AM
Hi
I started experimenting with replacing steel fastners with aluminium ones. It looks like I won't save 100g as hoped, but 40-50g I will. Not sure it's worth it TBH. Alu screws aren't cheap, and I'm only able to get them in one length so there's a lot of manual resizing that I have to do.
Well I got half way with it today before running out of alu screws. I might as well finish it though so will buy more next week and replace the second half. Photos below show today's weight saving.
ID:	3412   Click image for larger version
