MetalMan
MetalMan's Avatar
10.23.2007, 02:27 PM
Females on ESC, because if the males were on the ESC and the batt were plugged in with throttle applied and not motor was attached, you could short out the ESC.
Just curious, though, why 3.5mm? The MM uses 4mm plugs standard, and they will work much better than the 3.5mm ones assuming you don't use CC's male 4mm connectors.
