sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
10.23.2007, 07:23 PM
wow, this almost makes me want to build a G2R revo......and sell my UE stuff....
Bl E-REVO
Quark 125b
Castle Creations-Neu 2200kv motor
((2s2p)(4s)
7800mah 7.4v Lipo Pack
E-Revo 1/8 scale Hyper 7 CD
http://www.rc-monster.com/forum/show...1&goto=newpost
  Send a message via MSN to sjcrss
jordan...
one.five.two.seven
10.27.2007, 06:24 AM
hey clod, just lookin back at the pics, you don't have the nut on that comes with the strobe sprong kit, how tight was your slipper, and how did you do it up tight enough?
also did you use the stock slipper plates with the strobe?
thanks
jordan
ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
10.27.2007, 11:43 AM
nope - there weren't enough threads exposed to put the nut on. i hand-tightened the sprong, and it went as far as i could tighten it - i had punch control set low on my MM, and if i hit the throttle hard i could tell the strobe was slipping a bit, but i didn't want to take a wrench to the sprong and risk damaging it. it seemed to work ok as it only had a little slip here and there.
the strobe uses special friction pads, so the stock plates aren't used.
Eflite Blade 400 heli on 3s
jordan...
one.five.two.seven
10.27.2007, 08:41 PM
i see, ive got the other hi temp pads, does the sprong just go straight onto them?
could you please tell me what order you were running things from the tranny, ie. motor mount, pad, slipper..., but in the right order
thanks
jordan
