Finnster
KillaHurtz
Finnster's Avatar
10.24.2007, 10:16 AM
I do it. My 16018 seems to get some sort of weird braking glitch if I dont. What happens is that randomly when I apply the brake the ESC will not. Autotune seems to fix that problem for me.
Hmmm, i have a braking glitch as well, I wonder if this will fix it, as I haven't been able to tune it out. How exactly do you do the auto-proggy?
I want rev locked out, does it turn this off? Or do you go back and reset it to oneway? Should I return all the trims to 0 before I start, I've adj alot of them to try and dial it out. Does this reset the Tx throws like you initially setup when you go into programming mode?
