Charger Help
rc4x4nut
Charger Help - 10.24.2007, 07:06 PM
Hey guys Im looking for a new charger and I am set on the Hyperion EOS1210i. I read that it had a built in power supply, does that mean that I can plug it into the wall?
Thanks
sikeston34m
sikeston34m's Avatar
Smile 10.24.2007, 07:10 PM
Hi,
Yes I believe it does mean that. Some chargers come more as a "field charger", with battery clamps to hook up to your auto battery.
When it says it comes with a power supply, it means you can plug it into the wall.
I just purchased a MRC Super brain 989 charger. I'm VERY pleased with it.
rc4x4nut
10.24.2007, 07:15 PM
Thanks, Much appreciated.
JThiessen
JThiessen's Avatar
10.24.2007, 07:23 PM
As far as I know the Hyperion does NOT come with a built in power supply. You might want to double check that info.
10.24.2007, 07:32 PM
That charger is in fact NOT capable of plugging directly into the wall. It needs a 12v DC power supply. To use the full power output capabiity, you'll need a 12v source that can supply at least 24 amps.
Here is the manual: http://www.b-p-p.com/EOS1210i-MAN-ENG.pdf
sikeston34m
Smile 10.24.2007, 08:05 PM
Dang! I'm not exactly batting 1000 today.
Could there be another version?
Where did you read that it has a built in power supply RC4x4nut?
gixxer
gixxer's Avatar
10.24.2007, 08:37 PM
hyperion makes a 5i that is ac/dc. it is limited to 5amps though.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
10.24.2007, 09:02 PM
Lol, some days you are the bug, some days you are the windshield...
jnev
jnev's Avatar
10.24.2007, 09:55 PM
I can also assure you that it does not have a built in power supply since I used to have it. This is also the reason I sold it. I didn't have the money for the power supply.
I bought the MRC Superbrain 989 instead, and I couldn't be happier with it.
rc4x4nut
10.25.2007, 08:28 AM
Well I have to find that site that I read it in but what do you guys recommend for a power supply.
johnrobholmes
johnrobholmes's Avatar
10.25.2007, 09:48 AM
Cheap and powerful
http://www.web-tronics.com/1512siouposu1.html
