ncalenda
Need for Speed
ncalenda's Avatar
10.30.2007, 03:10 PM
Yes, min throttle is the brake position.
Here is that Petr said is the highest value possible. If you are too high you get the warning beeps like I did, which was BEEP..BEEP..BEEP over and over.
min value to be <= 1.1 or 1.2ms, no higher.
Good thing I bought the computer USB+, otherwise I would not have figured this out via email. Also, once the MIN value is wrong, you can't program it at all using the card or the PC. Well, what I didn't try, was to correct it via the PC, I might have been able to. Either way, I think my receiver may be the issue, since I'm having cut out issue with my other ESC.
  Send a message via AIM to ncalenda
