Surface mount component soldering
GriffinRU
11.03.2007, 10:52 PM
Originally Posted by
offroader
How do
you
remove the bad part?
I use a hot air butane blower to heat the soldered legs of the chip to be removed and lift it off using tweezers once the solder melts
Won't work for Power MOSFETs (with solderable tab) and with PCB layout with improved heatsinking.
GriffinRU
Find all posts by GriffinRU
