BlackedOutREVO
11.05.2007, 12:52 AM
What motor would I run on 2s in the pede? Most likely not 3s, because I have my TrakPower, but its possible I could do a 3s FP, but IDK
What should I use? I need all options, traxxas, to NEU, what would be the good choices?
Also, for all the tranny pieces, do they just sell the idler shaft?
I have this so far.
Planetary gear differential with steel ring gear (complete) (fits Bandit, Stampede, Rustler) $15.00
3696 Idler gear, steel (30-tooth) $3.00
4607 Ball bearings (5x11x4mm) (8) $24.00
3793 Input shaft (slipper shaft) / spring pin $3.00
5552 Rebuild kit, slipper clutch (steel disc/ friction pads (3)/ spring/ pin/ 4.0mm NL) $8.00
2554 Screws, 3x6mm cap-head machine (hex drive) (6) $2.50
5556 Slipper pressure plate & hub (aluminum alloy) $8.00
3195 Top drive gear, steel (22-tooth)
What else do I need to make a complete tranny?
EDIT again
I need 2 red heat sinks, depending on the motor, I want to make it more red (given its not a black NEU lol..) I need a more thin heatsink, but with no holes
