glassdoctor
TEAM FUSION
glassdoctor's Avatar
11.05.2007, 03:26 AM
Caps are marked with a "-" which is connected to the neg main power input.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
offroader
11.05.2007, 12:20 PM
Use a meter to see which side is -ve check for continuity between the negative side of the power and the solder points.
