Candyman2
Candyman2's Avatar
08.08.2005, 01:03 PM
Hello everybody! Ive not run the truck for a while, other things going on in my life. Also the spur gear had come loose on the slipper and stripped it. I got a new gear but there is a lot of work (dremeling) of the gear needed to get it to fit as its a 56t from the ofna 2 speed set.
The clutch is strong, its not as good as the strobe i think but it can handle this without a problem. The only prob i had before was a little too much slip leading to a lot of heat and then plastic parts getting melted. That aside it all seems good now, you have to catch it right to pop the front wheels, its a lot lighter and the centre of gravity much lower, as you can see hardly any body roll or risk of flipping over, it almost looks under control!
