My CCBEC is set to 6.2v. I use a Hitec 5955TG, which is very similar to the Hitec 5995TG, which is rated up to 7.2V. The 6.2v should give me a little extra power from the servo, resulting in about 350oz of torque.
Running at least 6V will help tons with servo speed, response, and torque. 5v is ok, but you don't get the most out of the servos...
the castle link from the mamba max is different from the mamba25? just wondering, because i haven't changed my bec settings yet, and i have the mamba max cable.
Yep, the cable you use on the MambaMax is just a USB cable. The MambaMax has a USB port. The Mamba25 (or the BEC for that matter) don't have a USB port, you program them through the plug that goes into the receiver. That's why you need a little adapter between your USB cable and the unit. They call it the Phoenix Link.
A little off-topic, but has anyone dissected one of those caste link cables? I imagine it plugs into the throttle cable and then into USB (or serial port). I'd be curious to know what interface IC is used...
Would it be any help if I look at mine and post any numbers on that IC?
