11.06.2007, 06:52 PM
just an update on my motor situation. i get no warrenty since i pulled the motor apart. i figured since i can't have a warrenty i would do some investigation of my own. i've determined that the magnet/rotor assembly is waaaaayyyyy out of balance. we have a granit table at work for inspections and i can't even get the thing to roll across it controllibly. the paste they use at the factory looks like they just missed their balance spot. its to the side of the heavy side. in just the small runing i did it wiped out my bearings and marked the coils inside the can a little bit. i specifically remember when i first got it, the motor would turn silky smooth by hand, now its jumpy like a brushed motor and you can also feel crunchy bearings. it destroyed itself in minutes.
oh yeah, i also ordered a new 10L since their cheap and i was pretty set on using it on the build. if it goes the same it'll be my last feigao and i'll pry some kind of warrenty out of the seller or discount on a better motor.
