11.07.2007, 09:15 PM
OK just makin' sure I was hitting the LVC and not over discharging the packs. When I ran it after about 30 mins it all of a sudden lost power, like it would barely move, I didn't run it after this happened as I assumed the LVC kicked in but I wasn't completely sure if Mike had set everything up when he installed the equipment. Though I did check the battery stats on my charger and the 3s showed a voltage of 9volts and my 2s showed 6volts so I'm assuming the voltage cutoff was right at 3.0v/cell, which to me sounds about right. After reading through my Quark manual 3.0v/cell is the highest voltage it allows the cutoff to be at. Does this sound ok?
The wisest mind has something yet to learn. (George Santayana)
