Smoked Quark, Works perfect
mmdooley
mmdooley's Avatar
Smoked Quark, Works perfect - 11.07.2007, 11:51 PM
Hi all, Check this out, I could not get my Quark to beep (program) so I hooked a battery pack to see if it was the UBEC and it smoked bad . and I had not got to run this $275 esc yet and I was feeling bad and mad . It should not have smoked, Because the battery was 7 volts and I double checked the wiring. Anyway now the good part I read here that the motor has to be hooked up even though the instructions say not to?? So I hooked it all up using the UBEC and when I tried to program it. It Beeped So I programed it and it works perfect Well almost perfect, I can't get the reverse to work. (probably the operator ) I am assuming I burned the internal BEC see pictures below. The burned part is at the left under the two large black squares. Can someone tell me why I can't get reverse?? And should I get the 125 fixed?? I guess an was with me that day
Thanks
WE DON'T STOP PLAYING WHEN WE GET OLD. WE GET OLD WHEN WE STOP PLAYING.
11.07.2007, 11:56 PM
Well, the motor HAS to be hooked up or the beeps won't sound. And, IIRC, the manual says to hook up the motor, but disconnect the pinion.
I don't think it was voltage that burnt the BEC; it was probably shorted or something and the overcurrent is what blew it.
Makes sense that it works when you use a UBEC (as long as you don't remove the red wire) since you're basically powering the brains via the UBEC. As a matter of fact, I've thought about disabling the BEC circuit altogether so it would run cooler.
Not sure why you don't have reverse though, unless the Tx wasn't calibrated right and/or the settings weren't programmed right.
Make sure your radio throttle EPA is set to 100% (or even higher) in both directions and the throttle trim is set to 0.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
11.08.2007, 12:09 AM
Ouch! Something like that happened to my Quark the first time I tried it... mine had catastrophic failure mode, however!
Yes, I would try reprogramming the esc, sometimes it doesn't work right when setting min/max EPA.
mmdooley
mmdooley's Avatar
11.08.2007, 12:38 AM
When I read " The motor should not be connected to the drive train during programming" I mis understood I guess I need a wake up call . But I have the red wire unhooked because it says "OPTO modification must be applied when using batteries above 10 cells Ni-MH or 4 cell Li-Poly. and it shows the plug and says to disconnect the red wire." Am I mis understanding this??
I read here on this forum a thread titled "Quark 125B" by ALL BRUSHED UP. For more info. But I think I am just getting more confused
BTW I have set my EPA on my MX3
mmdooley
mmdooley's Avatar
11.08.2007, 12:48 AM
Ouch! Bad to hear that it died (125) That's what I was afraid happened to mine. How much does it cost to repair one that has catastrophic failure. If you don't mind me asking?
zeropointbug
Z-Pinch racer
11.08.2007, 03:27 AM
...nothing
It did it right when I received it (it was a replacement unit), so I sent it back again, and they also sent a free BEC (Pro-BEC, made by S&T) which was nice of them.
mmdooley
mmdooley's Avatar
11.08.2007, 05:53 AM
I have heard nothing but good things about Quark customer service.
year 2012 Yes I am ready!
GorillaMaxx360
GorillaMaxx360's Avatar
11.08.2007, 04:48 PM
hey man dont feel stupid i did the same thing when i read that i read it fast in a hurry and thought it ment dont have the motor pluged in. so tryed to start it with the battery and it smoked. but when i disasemboled it it did not seem to have any damage. i am getting the motor wires soldered this weekend and hoping my esc still works.
2FastSS4U
RCM Brushless Savage
2FastSS4U's Avatar
11.08.2007, 09:17 PM
About your reversing problem, mine is buggy at best also, sometimes it works sometimes it doesn't... not sure what the deal is with it but as long as it's got brakes I guess I'm happy.
The wisest mind has something yet to learn. (George Santayana)
mmdooley
mmdooley's Avatar
11.08.2007, 10:19 PM
Originally Posted by GorillaMaxx360 View Post
hey man don't feel stupid i did the same thing when i read that i read it fast in a hurry and thought it ment dont have the motor pluged in. so tryed to start it with the battery and it smoked. but when i disasemboled it it did not seem to have any damage. i am getting the motor wires soldered this weekend and hoping my esc still works.
WOW, Did it smoke where mine did (see pic's) If it did you may be OK. I think that is the internal BEC. One thing I have not figured out is, Does the middle wire (red) get disconnected or not. The wire that goes from the esc to the throttle slot on the receiver. Right now I have mine disconnected and it seems to be OK. Thanks for making not feel so stupid Good luck !
mmdooley
mmdooley's Avatar
11.08.2007, 10:42 PM
Yeah, I got brakes and not having reverse is not terrible. But I am going to try again because they are good to have for bashing.
GorillaMaxx360
11.09.2007, 07:26 PM
hey actually when i dissisamboled it it did not look black or burnt anywhere. i have been building this truck for about 1.5 years now and today i got the motor hooked up and programed the esc. i was so amazed at its power. it was crazy almost to fast and after 3 min the controller caught fire and smoked like a fog machine. i will be waiting untill summer to drive it again.
nl12
nl12's Avatar
11.09.2007, 11:06 PM
contact quark service they will hook you up
jhautz
jhautz's Avatar
11.09.2007, 11:11 PM
I agree. Send it in to Quark. I have heard that they are very good about things like this. They just replace it from what I have heard.
to make it...
or break it...
Silent...But Deadly
coolhandcountry
coolhandcountry's Avatar
11.09.2007, 11:24 PM
My experence with quark has been great.
Did you try the double pump for reverse?
I got mine set for push reverse twice to work.
Peace!
Country
Help support the
Rc-Monster
Buy here
