Finnster
KillaHurtz
Finnster's Avatar
11.09.2007, 01:14 PM
Nice job!! Thats the same track that the RCM bash was at, right?
Yeah, same basic layout, but they redid the end of the track to accomodate the RC MT side by side races. The enormous triple was toned down a bit, where the last jump was more a tabletop leading to a turn, but it was still a good jumping track.
Also, I went up on the springs from the bash. I ran golds in the front w/ 60wt oil, and in the rear I went upto tans w/ 70 & then 80 wt. It was doing really well overall, some more tweaking should get it in.
The rear is still a bit soft, even w/ preload all the way down. The spring rate seemed pretty good, but the intial rate was a bit soft. I may try some blks, else go to the 120mm springs to take off a bit of the pre-load.
I also recieved my TrueRC 8S 3200 15C batts right before the bash. I ran them in the mains and was pretty pleased, may more power then I can use. On the 10 min main I used up 1600mah, including a bit of driving around during the warmup. The batts are 650g, and can certainly be sized down a bit for shorter mains, but you never know until you run it. Should do a 15 easily. 8s A123s may work good as well.
