Hey guys,
I finally got around to doing some sort of tutorial on how I built my A123 stick packs (from cells taken from Dewalt 36V packs). This way causes a (IMO) perfect 2p setup, where you can use any number of cells in series (of course limited to the maximum length your vehicle can take). In order to do this, the cells should have the nickel strips (welded on by the factory) cut to the width of the cell (so they don't protrude past the diameter of the cell). Here is my explanation of it:
1. Line up 4 cells in a straight line, with the 2 inner ones being either + or -, and the two outer cells having the opposite charge. I used this copper battery braid:
http://www.newcreations-rc.com/Produ...umber=HLA99012 It's actually a copper color.
Anyways, cut two strips of the copper braid to a length that covers the nickel tabs of all four cells. After doing this, solder the copper braid to the cells in the orientation shown (this way, it doesn't cover up the vents). The orange rectangular lines represent the copper braid, and are pretty representative of its actual width.
Also, you can solder a short piece of copper braid to the section between the two middle cells that can be used for adding balancer wires to.
2. Take the two outer cells (of the 4 soldered together) and rotate them 180 degrees, so they sit on top of the (previously) middle cells. When first soldering the two strips in step #1, make sure that there is no solder along the joints where the outer cells are bent at (otherwise, you won't be able to bend the copper braid).
After that, make two strips that cover the (now) top two cells. For a 2s2p setup, you will solder the main power wires on these. You can also solder on a short piece of copper braid for balancer wires.
3. Tilt the pack so that you can see the terminals of the bottom two cells (shown in "3D"). Do the same thing with the two copper strips as in #2, along with the short piece for a balancer wire connection. This end will also have a power wire connected to it.
Notes:
-In step #1, I like to use strapping tape to tape the two middle cells together before soldering them to keep them from moving around (and potentially messing up the soldering). Since these cells won't be separated during the rest of the building process (or ever, for that matter), this tape can be considered permanent.
-In step #2, you can lay the pack on a flat surface and tape the two top cells together before soldering the top terminals. You can also use the strapping tape along the length of the pack to keep the pack from flexing between the two groups of cells.
-For a 3s2p pack, you would do the same process, except that in step #2 you would add two outer cells to the top two cells like in step #1, and
then finish off steps #2 and #3. You could repeat this to make a Xs2p format (where x is any number of cells in series).
When finished, you can top the pack off with some shrinkwrap. The shrinkwrap needs to have a minimum (flat) width of 70mm to fit this stick pack.
Let me know if any of it doesn't make sense, and I'll do my best to explain. BTW, I have done a total of 4 of these, with two 2s2p and two 3s2p, where a 2s2p and 3s2p are used as 5s2p in my Revo and X-Terminator. For quite a few runs now, these packs have held up very well!
