lutach
lutach's Avatar
11.15.2007, 05:28 PM
Originally Posted by squeeforever View Post
If it doesn't have the 22 series pattern, whats the point?
I just found out the 22 Series does fit the current mount. I had to open the cut out just a bit to fit the 1521 4MM motor screws through. I will try and mount the 2250 later today or tomorrow the the other mount before I try it to the mount thats in the truck now.
squeeforever
squeeforever's Avatar
11.15.2007, 05:45 PM
I'm pretty sure the 22 series has a different pattern, but if theres enough adjustment, I guess you could make it fit, given the size of the screw holes are right.
lutach
lutach's Avatar
11.15.2007, 06:35 PM
Yes, the pattern is different, but in a way that you can actually have 2 of the hole line up perfectly. I'm such a retard for not noticing this before. There are 9 holes total and if you choose one of them and use the third hole from the one you chose, you end up with a 25MM spacing.
squeeforever
11.15.2007, 09:33 PM
Interesting. I was actually considering making a mount for the KB45 to put in my LSP, but I figure a XL on 6S is more than enough.
11.16.2007, 06:01 PM
You'll get more brownie points for using the KB45 and doing something 'different'....:) would be nice to see how well it performs/holds up etc.
squeeforever
11.16.2007, 07:45 PM
I'm still thinking about it. If it'll fit between the braces, no problem, I'll go that route.
lutach
lutach's Avatar
11.16.2007, 08:34 PM
You will need spacers to make it fit.
squeeforever
11.16.2007, 09:16 PM
Even though the motor will sit considerably lower than usually? Its only gonna have a 44T spur.
lutach
lutach's Avatar
11.16.2007, 09:20 PM
You can cut the brace like I did or add spacers.
squeeforever
11.16.2007, 11:57 PM
Damn, I don't really wanna do either...The CF isn't strong enough to cut I don't think...It would be in the week area of the braces...
lutach
lutach's Avatar
11.17.2007, 12:24 AM
All you have to do is add a 5mm spacer on each side of the brace. It should give enough space for the KB45 and in my case the finned Neu 1521.
